gooffeyguy
Tom
I would think the closer to the engine the better/more accurate it would be for the fuel that the engine is running on
i dont think theres anywhere to add it under that already as qdc fittings. i cut mine in right by the abs module where it jumps from the frame to the transmission.
i used flaring tool and tube sleeve/nut but yea same concept.... i dont like using compression fittings but thats just meHaven't gotten under it yet. Work called.
The QD I'm probably thinking of is the EVAP purge line. So you cut the hard line and used the compression to 3/8" or AN adapter?
*EDIT* Sheeeiiit. Only $12 each: https://www.racetronix.biz/p/adapte..._nC7q_sNn7fSO-aEuuNYkd7mNHa9dyXRoCKnoQAvD_BwE
So the fuel that's in the rail at the injector getting squirted into the combustion chamber is the same fuel that's 5 feet down the line, or at the tank? If so, why are you currently sampling it at the rail and not just from the handle at the pump?Lol
It's the same reason why I keep a few coils in the air hose. I want the air going in my tires to already be round.
Do post your process. I believe I'll be needing that after seeing what my junk is reading.I have the same O2s as you, as spec'ed by RA. Maybe they work fine for general engine operation but not for the alcohol calculating part. If I can add the physical sensor in where I want it, I'd rather spend the cheese on that than two new/different O2 sensors and still likely not be as accurate with alco %.
I'll be under the Hoe shortly...
Not really testing the fuel at all. I just know that when I buy 89 and it is supposed to have no more than 10% ethanol and the Tech 2 shows that my truck has calculated it to be 25% - 35%, either the truck is reading wrong or the gas stations are really ripping people off. Not super scientific, I know, but that is the truth none the less.Great timing and looking forward to your alc % results! How are you testing it- test tube with water method? I've never heard of the Denso P-B664 in all of this.
Kind of interesting when I look up the Denso 234 4668 that O'Reilly's shows a picture of it, and if you zoom in, it is the P-B664... I don't put a great deal of faith in what sellers post for pictures but it is curious just the same. Also, get your tinfoil hat ready... 4668 is kind of like B664, but BACKWARDS!!!... lolDenso 234 4668 is what RA was saying for mine that I ordered![]()
