Have power won't start
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I personally was confused as to whether it was a crank and no start or no crank and he/she offered no details that pointed one way or the other. I thought with his/her opening statement about starter, alternator, battery and key cylinder that it was a no crank problem and may well be that after all. It would have been better if he had said starts after sitting for 3-4 days for 2-3 times and then no start but why no start? No crank, crank and no start, crank slow....etc. Need some help and really, I don't want to waste a lot of time chasing things. I dealt with that when I ran shops. I asked lots of questions and made them talk to me. It was called "Systems based diagnostics".
wsteele
My guess was no crank as he had the starter tested.
I mean, if the starter turns over and the engine doesn't start and you have the starter tested, it really doesn't matter what any of us suggest as he won't be fixing it himself. Just sayin'. :)
Frankly, I disagree you need to be a clairvoyant to offer likely accurate suggestions to fix an engine that won't turn over. Am I jumping to conclusions that it isn't turning over when he tries to start it and it won't start? Sure.
But if someone comes on and says his engine won't start and he has replaced the battery, had the starter tested and replaced the ignition key cylinder, while it is a jump to think his starter likely wasn't turning, it isn't too much of a leap. The list of things it might be, given he has a new battery and has had his starter tested good, well, isn't that long a list and most of the likely ones have been mentioned.
But then, maybe his engine does turn over when it won't start. If he comes back at all and we find out that is the case, it will likely be a longer and more rewarding thread for all who like to solve puzzles.
Come to think of it, I might be jumping to conclusions it was a he. I mean, just because someone picks a handle of James, doesn't make them a he...
if there is known good battery and known good starter and it's not starting the most logical thing to think without any other info is to verify power to starter, if not then proceed to other things like starter relay (you can fire the starter from the relay slot) if that test good then proceed to relay to ignition, so on and so forth. seems to me to make sense that if the starter was tested and battery was tested then obviously it's not "cranking" and the rest of that mumbo-jumbo is irrelevant/ Grounds and power would seem to be the most logical issue.
bottom line yes more definitive information would be helpful but we don't always think about it
wsteele
I think you are preaching to the wrong guy.
intheburbs
SE MI
See, this is where the ambiguity plays in. My conclusion is exactly the opposite - truck is cranking, but not firing. Hence my suggestion of holding the gas pedal to the floor. Flaky fuel pump on its way out would be one of my culprits.
But again, pointless speculation until more information is given.
RET423
Not starting means it is cranking but after years of hearing people say "it won't turn over" when they mean "it won't start" I have given up trying to guess the actual symptom; if I had to guess I would guess that he is having an intermittent cranking issue but it starts fine every time it decides to crank, which would likely be the neutral safety switch.
So a wild guess at the symptom and a repair suggestion based on the wild guess
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
When I talk to anyone who said, "It won't start", I immediately ask, "Does the engine spin/crank and not start or does it not turn over/crank, like a dead battery?" Then they would typically latch on to the one word I said that they understood and that was, "I know the battery is good". Then I would have to say, "No, I am not saying the battery is dead, I am asking about the symptoms". I would remind them that "engine will not start" is a very wide area to look for problems and my asking them for info, as a service manager, will save them money. I had to tell them that narrowing down the field of the problem makes it faster for the tech and therefore less expensive for the customer.
Too many times they have no idea what is going on and they don't want to sound like they are clueless, so they latch on to something they know about, like the "battery".
I threw a guy out of my shop one time when he refused to shut up while I was asking the owner of the vehicle, his girlfriend, questions about her vehicle problems and he would not stop throwing in his own assumptions and thoughts of how we should proceed with the diagnostics. The girlfriend thanked me and when we replaced her failed alternator and worn belt and she came back to pick up her car she told me she broke up with her "know it all" ex-boyfriend.
We both LOFAO!!!!!!!!!!!!!!
4plemons
