Matahoe
Is that a bare head?
Nope. It Includes all valve hardware. It's delivery only.
Finished dropping off head at engine shop. It's $25 to test. $100 for exhange.
Ahead of schedule, shoulda planned on throwing a cam in it![]()
Yeah, I am excited too. Wanna start this up SO bad. Just having the heads off and removing the broken off exhaust manifold studs seems all worth it. Plus the fact it is going to run a whole lot better....AND get better mileage to boot.Good to see progress, I'm excited for you!
Great jobWell today was the day. Crossed my fingers
Make sure oil and filter was changed. Check. No gas leaks..Check. Battery connected. Check. Coolant...etc.
Ignition sequence in 5, 4, 3, 2, 1....
Wah.. wah.. waaaah!
Nooooo! It ran rough as ever with flashing CEL on ! Not now girl... What the heck did I not do right? It seemed like it was only firing on half the cylinders. Had to make a one mile trip to drop daughter off at dance class running rough as ever sitting in traffic with CEL..taking 30 seconds to pull out of an intersection going dog slower than a ww1 tank.
Got back home...scanned for codes. Got cylinder2, 4, 6 misfire and a whole bunch of coil codes. Well as it turned out I forgot to connect the right bank coil packs to the harness connector. I connected it up...then cleared the codes and started it back up. Been running fine ever since...no CEL. Actually it runs great! No more rough idle and it seems like more power at higher rpms. There doesn't seem to be any fluid leaks anywhere and the exhaust is not leaking anymore. After about 4 weeks of taking my time i can finally call this project complete. Thanks everyone for the moral support and help!
