yup, the speed engineering 1-7/8 i have were pretty cheap under 400 iirc, longtubes and ypipe, deletes all cats. fit is pretty good I had to massage the driver side a little bit to get rid of some rubbing under acceleration, they make a 1-3/4 that are a little cheaper and might not have the same problems.
i couldnt get the ypipe to seal up that great so i had a friend weld some vbands at each header, all the slip connections and will eventually vband at the connection to the stock exhaust. still trying to decide if i want to try and stuff a small resonator on it somewhere to quiet it down some more
