Headliner R&R…? anyone?
Chubbs
Chubbs
I've used that product a few times with disappointing results. In my personal experience 3M is the best for this. Hopefully you'll have better results then I did.
oh $hit! not what i expected to hear. i work at napa and thats what we carry
latvius
Ariton Alabama
I used 3m but I made the mistake of putting it back in the same day I glued it. The heat from the next day caused it to separate and sag in spots. If my memory is correct I read somewhere to let it dry for 3 days before you try and install it back to make sure it is glued good. I did that after I redid it (mine was a 95 bronco, so much smaller liner), 3 days may be excessive but I wouldn't want to do it a 2nd time.
Chubbs
Chubbs
ya i hear that. this headliner is never coming out again, at least on my watch. i will be glad to get it back in. lucky, more like it. was a PIA to take out, and its going to be 2x the difficulty getting it back in because of the caution needed not to dirty it and such. plus getting all of the holes lined up where everything goes back in with the tacks, and trim, etc. this was a much larger job than i had anticipated and fortunately for myself i didnt put a lot of thought into it lest i would have skipped this headache altogether and just set it on fire.
Chubbs
Chubbs
and its been sitting for almost 24 hours now. I may try to stick it back in tomorrow night or sunday. the weather has been great as far getting that headliner glue set and cured. mid to high 80's daytime and low 60's at night... and zero humidity, slight breeze - i would bet that its good and set by tomorrow for sure.
in the meantime i would like to get my cluster working again. i'm still researching on what type of bulbs go in the gauges and what type of solder is best suited for the circuit board. the gauges all worked properly when they worked. the whole pod itself goes in and out. except this time i can't get it to kick back on since i removed it for the headliner thing. so whatever intermittent bad connection that was going on before must be completely separated now. i'm thinking its a wiring issue since i have no power at all to the pod. i saw a video that discussed a short in the wire loom where it runs through the engine bay and bolts to the engine block. except that when the pod did go out, if i beat on the dash and the face of the gauge pod enough times, or hit a pothole, it would come to life. not this time. at least i have one idea. i can trace the wires behind the dash and look there too. because i can't get blinkers on there, or messages so it must not be getting power and/or signal
Good idea.
dps01
N. TEXAS
Got burned using rattle-can adhesives. The 2nd time I did my 03 Tahoe was with professional adhesive and an inexpensive harbor freight paint gun.
Adhesive worked great, but was unforgiving… have a couple small wrinkles, but not bad enough for a redo.
Chubbs
Chubbs
You removed and repaired the headliner 2x??? God bless you
dps01
N. TEXAS
unfortunately, yeah… plus a few other vehicles with their own set of issues. Have to redo one of those again too…. All GM, and all initially had the foam backing turn to dust..
I have a healthy respect for those who do this type of work for a living…
Chubbs
Chubbs
if this glue doesn’t hold the headliner I will just pull it out and put on the trash pile. No way I’m reupholstering this dude again. I really hate to hear that. Wish I had done more research and used a commercial/ pro adhesive BUT if I had done more research I would not have this headliner out right now. Or ever
Chubbs
Chubbs
It’s definitely an art and nothing you want to get in a hurry or rush. I would do it for payment but for my own satisfaction no there are 100 other things I will do before the headliner.
Almo7annad
