Heated washer fluid .... Update!!!
zach2011
Platinum Member
Thanks for the discount...I wonder if we can get both of our threads stickied so anyone who comes by can see the heated washer fluid fix and a discount for it. :)
zach2011
Platinum Member
can it be used on 01-06 models ?
I've heard Alphatherm makes an aftermarket unit that can be used on any vehicle, you'd just need to wire the switch.
This model requires the OEM 2007+ wiring harness for the windshield fluid heater module.
zach2011
Platinum Member
How do you do it? I guess it will be easier for me once mine is gone but I'd still like some instructions.
Punisher66
Albany, NY
Can i put it in my 07 that does not have a factory one? Or did it and it was removed?? Bought it used, how can I tell.
zach2011
Platinum Member
The button should still be there, it's next to the right 12v outlet below your AC controls.
2909K
Pittsburgh, PA
Just ordered mine...Hopefully they give you instructions on how to install. I can't imagine it to be that difficult.
Thanks for the info.
thewheel82
