Heater hose connection,leak
HDRock1
Flint,Mi
I don;t how this connection is supposed to be??
The pic is not the angle I wanted, but it is leaking and looks like it is not seated.
How do you remove or connect the connection ?? FSM says special tool
SunlitComet
OBS Jedi-Do Good
unknown at this time.
While cold squeeze the black tabs and pull. You can get a whole new part set for under $10 in help section of parts stores. It has the metal screw in piece orings and plastic retainer. Do not Replace screw in piece unless really needed.
---------- Post added at 10:54 PM ---------- Previous post was at 10:53 PM ----------
It will move a little BTW but should not leak.
HDRock1
HDRock1
Flint,Mi
Thanks
992dr
Eastern N.C.
Not too bad to replace the plastic and o-rings. Check inside for corrosion, if its bad enough you may have to replace the fitting itself. To be honest, I'd suggest replacing it even if there is a minute amount of corrosion, better to catch it and replace than let it build up and have to do it later on. Better to be safe than sorry, I would consider it preventative maintanence.
HDRock1
HDRock1
Flint,Mi
Drove the truck about 20 mi today and it isn't leaking any more but I got the new part And will fix it to be sure it doesn't leak any more.
The old part that screws in looks like it might be plastic is it ?
Pic is new part
ChrisAU
Birmingham, AL
Be verrrryyyy careful taking it out. They break super easy and when they do, they are a b*tch to get out.
SunlitComet
OBS Jedi-Do Good
X2 i said the hell with it new heads, blast the manifold clean and took it out. manifold became instantly trashed because thread were shot and severe pitting.
bdewitt205
