HELP! 99 Tahoe making noise in rear
daftahoe
Im not sure if there is a thread like this but....
On my 99 hoe, when I come to a stop and then pull away there is a "squeak" noise coming from my rear axel. Sometimes when I go over bumps the same noise is there.
I have pushed up and down on my rear bumper and cannot duplicate it.
I'm not convinced its my shocks or breaks.
Any thoughts?.... Thx
rolfsent
Cincinnati
I had the same exact thing happening with my 1999 Denali, I replaced the shocks because they were blown and the noise was gone. So you might want to check those.
D
daftahoe
My shocks are original. So are the leafsprings... Any idea the cost to replace these? And where would you go?
---------- Post added at 08:54 AM ---------- Previous post was at 08:53 AM ----------
What do you mean?.
bowtiefreak
No Quarter
Near Philly
bilstein. Check our summit racing. Around 50-70 a pop I think. Leafs just need grease or bushings
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Times ten I am reiterating my emphasis on spring leafs that squeak against each other. if the springs are not sagging do using polyurethane bushing are stick some grease between the leafs. I personally use and recommend Edelbrock Performer IAS shocks but have been discontinued and are getting harder to find $80 each. Edelbrock 3303 for front , 3403 for rears on a 4x4 OBS.
96redsport
Altoona, Pa.
I have a similar problem but not the squeak. It's more like a small thump that isn't always there when I pull out and it doesn't do it when driving or coming to a stop. Haven't got around to really looking into it cause it just started a few weeks ago and the weather hasn't been good enough for me to get on my back and look....
Christian_d
