Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Ive read through so many forums about the various types of quick disconnects, but haven't found anything for the i believe return hose from the heater core... ive been pinching the two white plastic tabs and pulling at the broken house but it wont budge!
If you snake a plastic tube in from the back spray some penetrant and let it work on the o-ring seal. That is the corrosion spot. After it sits for a while you can use your grips and try to spin the end and then pull off easily trying not to break the heater core spout.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
