Help Diagnosing Oil leak
lspann3525
Well im back again with another oil leak after a couple of oil pan gasket changes,rear mail seal replacement and valve cover gasket replacement.
Lately ive noticed my 08 tahoe has been drinking oil so I decided to check the oil pan area and I discovered the front area of the oil pan is covered in oil. I doubt its the oil pan gasket. I replaced it maybe 10 months. Im trying to pin point this im thinking maybe timing cover seal or crankshaft seal??? Anything else in this area that can cause this mess. Heres a video.. any suggestions will help.
donjetman
Oil consumption:
Install a catch can and have you or a PO installed the improved driver side valve cover per GM TSB# 10-06-01-008M? https://f01.justanswer.com/ebrock63...il+Consumption,+MIL+ON,+Engine+Runs+Rough.pdf
When you had the pan off, I hope you installed a new oil pump to pickup tube o-ring? Also, a dab of rtv is needed where the parting line of the front & rear covers meet the oil pan gasket.
Last summer I changed the timing cover gasket, pulley, seal, o-ring, VLOM, etc, etc, etc:
https://www.tahoeyukonforum.com/threads/valley-cover-crank-pulley-etc.149036/
L
lspann3525
I havnt installed the updated valve cover yet. I installed new gm pick up tube o-ring and put 4 dabs of rtv where the block meets the covers.
I want to assure its the timing cover gasket sort of hard for me to tell where its coming from. I cleaned that area up during the last oil change so where the leak is coming from its getting worser.
What made you change your timing cover gasket?
donjetman
In 2018 at 130k miles when we bought our road hard and hungup wet Yukon, the piston rings were stuck from sucking & burning oil because of the the poor original valve cover pcv design. Poor pcv performance/vacuum can cause crankcase gaskets to leak due to too much positive crankcase pressure. Today it has 199k miles and does NOT use any oil.
thats good
It had a small oil leak from ?somewhere? on the front of the engine.
The 2 piece pulley balancer is held together with rubber and we all know rubber doesn't last forever so I changed it and the seal.
donjetman
In 2018, when I had the oil pan off, I also installed the afm valve deflector shield GM# 12639759 ($8) per the TSB instructions, even though my engine is NOT afm equipped.
L
lspann3525
Is there an updated aftermarket driver side valve cover?? I was quoted 146 locally..
L
lspann3525
Thanks! Thats a pretty good deal. I will consider this for my gen 3 rebuild. Im going to try to find the cheapest driver side valve cover thats updated to see if that slows down the oil consumption. My oil pan /timing cover seems to be leaking. So ill start with the valve cover
Are all the valve covers with the part number 12570427 updated??
Ebay and Amazon are full of 12570427 aftermarkets that are half the price
L
lspann3525
They all seem to have the rectangle opening instead of the round opening as well.
Anothertahoe
