yukonese
- Joined
- Nov 5, 2011
- Posts
- 48
- Reaction score
- 2
2001 Yukon SLT 5.3L 4x4, 130K miles, 1st owner.
Day1,
Day2,
Questions,
A bit long, I tried to mention every detail for experienced people to give me some suggestions.
Thanks in advance.
Day1,
- Everything was normal, change oil light on, I changed oil in the evening, no action after poured 6 quart Mobil1. I planned to reset the computer next day as usual.
Day2,
- Unlocked the door by remote (electrical power should be OK at this moment) in the morning.
- When I tried to start the engine, nothing happened. I noticed no lights on in the cluster or interior.
- Central door lock didn't work, remote, radio, didn't work either.
- Opened the hood, the hood light didn't turn on.
- Checked battery voltage from the back of the terminals, 5V only (poor connection?). I suspected the Bosch battery was bad, it was 3 months old only. I decided to deal with it after work.
- Back from work, checked the voltage again, 12.7V, but no hood, interior lights on.
- Took the battery to Pep Boys (where I got it from), they checked the battery, 802 CCA, cannot be healthier.
- Put the battery back, hood light went on, a good sign. Engine started successfully, everything seemed back to work.
- I drove it around the residential neighborhood slowly, after around 1 mile, suddenly steering power lost, I found the engine RPM went down to 0, obviously the engine was off. The truck was still moving by momentum for about 200ft, I managed to pull it over.
- During moving with the engine down, the head/cluster lights were still on. The symptom was different from that in the morning.
- I restarted the engine successfully a couple minutes later, then went straight home.
Questions,
- Pep Boys pointed me to check fuses, especially the main fuse. I checked all big fuses in the electrical box, they are no bigger than 50A, all OK. Any other fuses I should check? Any single one can bring down the whole car?
- They found water in the battery terminal connection area. The possible reason is, I washed the car in a station with high pressure spray, but it's one week ago. I have been there for years, never found a problem.
- What is the possible electrical problem causes the engine to shot off during driving? But with the lights on. I didn't have any electrical related issues in my 19 year ownership.
- Could be the same reason that causes no any power in the morning, and shot off engine in the evening?
Thanks in advance.
