Oldman1985
- Joined
- May 30, 2017
- Posts
- 9
- Reaction score
- 1
Thank you so much knuskill for this info. I will definately get a second opinion. I wont be back home for maybe another 2-3 days and I will definately try it out.
I wouldn't waste my time with the dealers...the delete afm mod will not help if your cam is wiped. I'm an ole school racer and toy lover too and after dealer refused to honor their mistakes from a previous afm repair WITH THE WRONG PARTS AGAINST A TSB ISSUED MONTH EARLIER - I did it myself.
Went with a Comp Cam fairly mild, but more aggressive than factory than factory, LS7 lifters, did heads to spec, new springs and retainers, and replaced timing chain and water pump while in lol. This was at about 160,000 on my 2008 PPV.
Truck is a "beast", but still pulls 30' boat out of steep ramp like nothing and no issue in morning traffic. Gets around 15mpg when I drive "human" and just keep oil changed 0-30 syn or 5-30 since no longer afm. There are a few quick mods to intake and parts with gaskets cost less than $1000. plus chain, water pump and fluids. Labor at a shop that understands the vehicle should not exceed 1200-1500 MAX. Truck has close to another 100k, no issues.
have fun.
where are you??
Blackjack C-27
Oil pressure is good?
Sent from my SM-G950U using Tapatalk
Oil pressure numbers are in line.
2007 Chevy Tahoe LT 4WD Flexfuel
117xxx miles as of this post.
Purchased date
November 2016 113,*** miles
March 2017
@ 116,*** miles
Check engine light starts blinking
Stabilitrak Off / Service Stabilitrak
Traction Control Off / Service Traction Control lights would come on intermittently. When these lights come on the truck would drive really rough with a flapping noise and shift hard from 1st to 2nd gear and 2nd to 3rd. Then when the flashings disappear the truck would run fine and smooth again.
Code reads P0171= Fuel system lean bank 1 and P0301= Cylinder 1 misfire. I changed all Sparkplugs with ACDelcos Iridiums and AC Delco wires. Replaced coil on cylinder 1 and did a fuel injector cleaning with seafoam in the gas tank. The truck ran fine for a day then all the lights came right back on. The truck only operates roughly when these lights are on.
Finally took the truck to chevrolet to see what they come up with. Service manager says I have only 2 options since cylinder 1 valve lifter is bad and recommends I replace valve lifters, VLOM and the camshaft for about $5000 or put a new motor in for $7000 not including fluids and whatever else needed.
I cannot drive anywhere anymore as the lights would come on flashing more frequently now and im just paying for it to sit in my driveway.
I want to know how difficult of a job it is to replace the AFM Valve Lifters, VLOM and Camshaft? Can I just replace cylinder 1? What is every part needed to complete the job thoroughly. What parts brand is best? I know very little and only do maintenance work. Do I even need to do all of this work?
