Help with my drop trying to get the rear lower?
NathanJax
Vacation Nathan
Administrator
Jax, Fl
do you have shock relocators in the rear? That could help. If not, go with a 1" smaller spring...
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Yeah but it's still sits kinda high
Sent from my SPH-L710 using Tapatalk
Then you'll have to do smaller springs. If those are a 4", you'll need a 5" and maybe grab some 1/2" spacers so you can adjust it to be level side to side and with the front.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Question can I cut a coil off? Not sure
could you? yes, would I? No.
It could effect the spring rate which in turn would affect ride quality. IF you do, cut from the top, not the bottom.
I'd spend the $200ish and get new springs
T
torwanwilliams.tw
Ok that's good to know I'll get some springs I'm doing it myself so I know I'll make sum mistakes.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
What springs are you using?
T
torwanwilliams.tw
Crown suspension 4"drop coils are you the man everyone talks about and if so what do I need to do next? I know I need to cut the bump stops bracket off. But like I said I'm not a experience and do you sell parts?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Good luck with crown.
1) do you have shock extenders?
2) what rear shocks are you running?
3),non autoride truck right?
Tell me that and I can dial in a price and kit for you
rsyoder96
