Help with my drop trying to get the rear lower?
T
torwanwilliams.tw
Yes I do have shock extenders,factory shocks,no autoride
Sent from my SPH-L710 using Tapatalk
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
You will need to
1 do free travel mod
2 tgen I have the djm links and new bumpstops for axle for 110 shipped
3 I would move to belltech sp shocks 130 shipped
So 240 shipped for it all and cutting bracket off frame see how ride is. If still bad I would get rid of crown springs like I've done on many local suvs
T
torwanwilliams.tw
Thanks I wish you was in DFW area in Tx how do I order from you?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
i do everything thru paypal. I woudl set you up a custom bill to your email
T
torwanwilliams.tw
Ok cool the measurement from the hub driver side 18 1/2 passenger side 18 1/2 the back driver side from the hub 19 1/2 passenger side 19 1/2
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if it doesnt sit low enough after you do what i said you will need to go with my custom springs.
what size tires are on the truck? i would need ground to fenderlip measurements.
on a 305 35 24 on my custom spring and rear combo it sits at 32.75 from ground to fenderlip.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
32 11/16 on my custom spring in rear.
What does your truck measure from ground to fenderlip all the way around now?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
if you need 1.5 more you will need new springs for sure. Try first to cut off bracket and do what I said and go from that point forward
Rocko_Modern_Life
