HID's Out!
soulsea
Bar
Brad,
I will not dispute that there's always a remote possibility of an HID PnP kit work decently in a halogen housing. NBS Depo halogen projector housings are famous for providing a decent cutoff and beam pattern. BUT, when this happens it is incredibly rare and a result of coincidence rather than planning by the housing manufacturer. We know this cause none of the other Depo housings are so lucky.
Why?
Well, it'd take a stupidly long post on my part to outline it all, but here are a few reasons.
1. Halogen housing designs are incredibly varied and although it may not seem so, are complex pieces of engineering designed and optimized specifically to work with its corresponding type of halogen bulb (H1/H11/H13/etc).
2. The number designation of a halogen bulb is not limited to its base connector, otherwise they'd be a universal base connector. The number also designates the way the bulb illuminates, location of hotspot, depth in the reflector, whether it sits before a cap, whether it's in a fresnel housing lens, and many other variables.
3. Keeping No. 2 in mind, there is no such thing as a HID oem bulb. Philips, Osram/Sylvania, Hella, etc, have never, nor will they ever manufacture an H (halogen) designated HID bulb. When someone buys a say H11 HID bulb, it's a generic hid bulb connected to a halogen base ... this process is called rebasing and at a large scale it is very imprecise, and very rarely if ever are quality oem HID capsules used.
4. Keeping Nos. 2/3 in mind, cheap HID rebased bulbs, due to their low quality, rarely maintain a consistent hotspot, and given their own inconsistency and the different housings they'd reside in, matching the two into a proper beam is all but impossible.
5. Especially because HID bulbs illuminate in a completely different way that is by definition scientifically incompatible with halogen reflector housings. If one tries to put a H1 halogen bulb in a Mini H1 HID projector, the result is equally poor, that is simply because the incompatibility is applicable both ways.
There's a lot more but you get the drift, too many moving variables and incompatible optics/designs ... not impossible for them to properly coexist, but statistically highly improbable.
A couple of last points if I may bore you more ... :)
Quality of the HID PnP kit has very little to do with the resulting illumination, unless the aftermarket bulb is so poor that it doesn't work. Quality matters in the sense that if the kit is poor, it will not work, will use ballasts with the wrong current (AC instead of DC), will use cheap harnesses with inferior cable, all of which can result anywhere from headlight failure, to stuff melting inside the housings or the engine bay, or in rare occasions set the front end on fire. It happens.
But even if one were to use oem ballasts like Denso/Hella/Matsushita, high quality harnesses, and even pay an expert to rebase the highest quality oem bulbs in an H connector, all the elements I outlined above would not change and neither would the resulting output. One would simply have a high quality PNP kit with less chance of failing and/or inflicting damage.
Last ...
There is a massive misunderstanding and lack of knowledge as to what 'DOT approved' means. The DOT never approves or certifies anything related to headlights. The manufacturers are the ones responsible for ensuring that their lights meet NHTSA and DOT guidelines and express this by indicating DOT approved on their components. The DOT does do random testing to make sure that this is the case. But the idea that anything that says 'DOT approved', simply because it says so, can be used interchangeably is erroneous.
The process is simple, different manufacturers of lighting components self certify as DOT approved, be they Halogen/LED/HID/filament. Car manufacturers combine them for their vehicles, and once they are installed in the factory it is illegal to modify any element of them other than replacing a bulb like for like. This is specifically to prevent people from mixing and matching lighting components at will for the reasons I outlined above.
So even retrofits like mine where every component may have DOT approved stamped on it, are illegal. The only difference is that retrofits if executed properly, mimic oem setups whereas PnP kits don't. Still illegal, but less egregious to others and less likely to raise a leo eyebrow.
Yikes ... tired now. :)
More info in sig linkies.
Modded
That Guy
Let's just drop the topic because this had been brought up way too many times. Anyone who wants to discuss it can go here:
http://www.hidplanet.com/forums/forum.php?
:Handshake:
At the end of the day, this topic is very sensitive and way too subjective and posting here probably won't change any viewpoints.
soulsea
Bar
Seriously?
You want to squash a perfectly courteous conversation about automotive lighting in an automotive forum?
And one of your premises for this is that 'it probably won't change viewpoints' on a thread who's topic is the OP changing his viewpoint?
And did we cross into quantum mechanics making optics science 'way too subjective?'
I heart you big time Neo, but you're out of line trying to threadkill. :chillpill:
Fast55
Ventura County USA
I would think everyone would be interested. I believe I backed up everything Serge said, but without the same level of detail. a PNP kit can work, but as suggested, it almost assuredly was coincidence especially given the fact that I have found no other bulbs that just happen to put the arc in a location that works pretty well for a NNBS Tahoe headlight housing.
It's not likely to happen again because, like I pointed out, these housings are particularly bad candidates for a PNP kit. I believe the A6 worked well because the bulb was an H1 and in a projector housing.
In regards to DOT, I am aware of what they do. There is no "DOT" PNP Kit and although a true conversion is worlds better, there will never be a "DOT" conversion either.
What I've ended up with is probably the best combination of ballasts and bulbs from different manufacturers that is still not much better than stock lights, is not street legal, and is not even close to what a true conversion would be, all while costing me a lot of time, effort, and money.
Factory reflector based HID setups can work pretty well. My old E55 and daily beater work car (Toyota Avalon) had/have pretty good beam patterns. But if you've drive anything with newer projector HID's you'll see what Serge is saying.
Modded
That Guy
To me, this discussion is like politics. One 5 page thread is not going to take a far right person far left.
It has been discussed too much and there is really no point of another thread about it. Most people who have actively been on here for 6 months or more know that running HIDs in projector housings is the way to properly do it yet 95% of them do not have that setup.
If this was GMFullSize, this thread would have went south and got locked the first day it was initiated due to bashing rooted from people who are tired of HID arguments.
---------- Post added at 01:33 PM ---------- Previous post was at 01:23 PM ----------
And Serge, it is not like I am trying to say you are wrong, or inciting trouble. I am also not trying to ruin a thread because the OP made this thread to state he removed his due to reasons you stated and did not post a thread about PNP HIDs vs. Retrofits.
You are right in saying HIDs need projector housings.
I'm just saying that it is a lost cause to persuade members into running HIDs in custom projector housings only because the amount of $$$$ it cost alone is enough to make very few people invest in it.
More than likely the next generation Tahoe/Yukon will have projectors. Then maybe running HIDs will work perfectly and legally fine. I will be glad to run projectors now and then. But I am not dropping $$$ on a retrofits at the life cyle I am at on my current model. If I was going to keep it another 3-4 years, it would be a done deal to get retrofits. :Handshake:
Regency
Funny some say HID's are illegal when king county metro and sound transit are rockin them now
Regency
You? Didn't you say to phattyford that he would get multiple tickets for having mods including his HID's?
soulsea
Bar
I never said HIDs are illegal.
I said modifying factory housings in any way is illegal.
I even said on this thread that for the same reason hid retrofits are illegal.
But HIDs in reflectors housings tend to draw the most ire from leos because they often go to stupid kelvin levels and get so many glare complaints form other drivers. In fact the whole thing got looked at by the government because of so many complaints by drivers about glare.
How it got started:
http://www.nhtsa.gov/cars/rules/rulings/glare.html
The result:
http://www.sema.org/files/attachmen...-eNews-May07-Lighting-HID-Conversion-Kits.pdf
http://www.cbp.gov/xp/cgov/newsroom/news_releases/national/2011_news_archive/10062011_2.xml
To sum up: Unmodified Oem HID headlamps = Legal ... Any HID conversion = Illegal
But the damn kits and their glare got us all in the poop so now even retrofitters are outlaws! :)
QUYHMK
