High mileage Fluid Change?
S
Sdp1234
Southeastern PA
Smells normal, still red but a little dark. I’m not sure what I’m looking for but it looked free of debris. One spec that I saw may have been dirt that I transferred .
I’ll look again in the bright sun tomorrow. Hints on what the bad crud looks like?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
That looks pretty good but another sample with more light would be better. The spot shows a hint of brown and red. The red would be bright if it was fresh or close to fresh. You said 170k with little records, so now it is a call to make. If it was mine, I would do it, after seeing another sample tomorrow. But hell, I like spending other people's money.
SnowDrifter
Washington. The starbucks side not the desert side
Honestly that just looks dirty. Go ahead and change it
My preferred method is to either drop the pan or use a mityvac to suck fluid out through the dipstick. Not a fan of taking off a cooler line and starting the car. It's apt to run the pump dry. And these units rely on the fluid return path - it's not a direct return to pan.
If you drop the pan, order up a second magnet and toss it in there. TSB for it. No glue or anything else, it just sticks to the pan and stays there because of the mind boggling mystery that is electromagnetic forces
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
Magnets are a wonderful thing. Oil pan drain plug, diff plugs when can and trans pans. They can be eye opening.
twitchtucker
