Holley HI-Ram Intake manifold on 5.3
Y
Yukon82291
Goffstown NH
its cable :( does an underdrive pulley make a difference? my dad has a 97 yukon with one but thats a 350, didnt know if they made a difference on ours
Big Buttons
The SS Burb
South Texas
A little more off the line power but not that much. It's also a little less rotating mass. For the price of the underdrive pulley you can swap to e-fans which would be better and add about the same amount of torque.
Z-56 Hoe
What do I do????
Houston
Waste without a cam. Wont work on his 01 unless he is a rare one with drive by wire.
Sent from a jelly bean.
Jenn it works on my 2001 but I am drive by wire also and had to get the adpator from Texas Speed. I also have heads and cam too
FreshLikeOprah
He can run a cable 90mm TB. Holley, Edelbrock, Nick Williams, all make TBs.
What cam you going with? Stall?
Go with a TBSS/NNBS intake. Cheaper and better. You will need to modify your rails, or use a 97/98 Vette fuel filter and the newer rails, and make spacers to use your injectors, or get harness adapters and run the newer ones.
Abelton
