Hello,
I have a 2010 PPV (EX-Police) Chevy Tahoe and would like to soften the suspension because it has a very harsh and has a stiff ride.
I would like to make my ride quality like a 100% stock Tahoe and would like to know what needs to be replaced/changed to do so.
Please let me know if you know anything about it..
Thanks
Hello. I know this thread is getting old, but I am wondering what you ended up doing and what were your results. I want to soften the ride on my 2014 PPV a bit, too.
Like the O/P, I like the stance of the PPV. I definitely don't want to lower it. I don't mind if it ends up sitting a little higher. I just want it to keep it simple and ride smoother.
There are so many suspension threads! It sounds like I can leave the PPV springs alone and simply use OEM Tahoe LS shocks/struts. Is that correct? Even better, it sounds like I can use Bilstein 4600's for a Tahoe LS instead of the OEM stuff, right?
In regards to the springs, how do you know when they need replacement? How long do springs last? If the shop I use indicates I need new springs, should I have them use the PPV springs with the shocks I mentioned above (OEMs or 4600s for a LS) or the springs for a Tahoe LS?
Thanks in advance everyone. And, yes, you are correct, I have no mechanical skills.
