How many of you DO NOT experience buffetting and vibration problem?
Hayseed_Yukon
Yes. Same hayseed as bimmerfest. Does the yukon have something like the bmw connected drive where I can do online searches? She never gets motion sickness but the passenger seat in the X5 does it to her. Everyone else is fine.
Cmicasa the Great XvX
Here is my take..
Set-Up is Max Trailering Package, 275/55/20 Continentals, Auto-ride
I went thru the ride issue where I felt a vibration when going above 65 and in some instances.. suspension felt out of whack even at low speeds if hit even the slightest imperfection in the road.. this was AFTER.. I went to the dealer for an Oil Change and Tire Rotation where they also added air to my tires.. 35psi.. which is the recommended. I then commenced in dropping them back to where I was before I took it in.. 33PSI all around and the vehicle rides as smooth as a Caddy now. No vibration, not roughness.
ajs800
Michigan
Here is my take..
so basically, you notice a big difference in ride when tires are 35+psi vs 33psi or less?
Yep. Even my '14 Stingray simply rides better when it is around 33psi. The '14 Impala? Same thing. The '16 CTS-V? Yup.. I think the inflation numbers are because of fuel economy testing or something.. but I have no issue burning an extra gallon of gas if the ride is smoothed out like it tends to be at 32- 33psi.
ml55
Tahoe LT 2015 zero milage (6/2014 Built), The car suffer vibration and i got few times headache and dizzy after driving
Planing to change the tyres ASAP now the challenge which Brand i will chose !!
ajs800
Michigan
If you're not concerned about off road performance, you can't go wrong with Michielin LTX or Michelin premier LTX. I went with the premier making sure all RF balanced under 15lbs and buffeting was 99% fixed. I am sure many tires will be fine but make sure they RF them and they are under 15lbs. Shouldn't have to but these trucks are ultra sensitive.
Loose_Gasket
