How many of you DO NOT experience buffetting and vibration problem?
Yukon John
SE florida
Here is my take..
Set-Up is Max Trailering Package, 275/55/20 Continentals, Auto-ride
I went thru the ride issue where I felt a vibration when going above 65 and in some instances.. suspension felt out of whack even at low speeds if hit even the slightest imperfection in the road.. this was AFTER.. I went to the dealer for an Oil Change and Tire Rotation where they also added air to my tires.. 35psi.. which is the recommended. I then commenced in dropping them back to where I was before I took it in.. 33PSI all around and the vehicle rides as smooth as a Caddy now. No vibration, not roughness.
I have the same set up in my 2016 SLE...including the same wheel/tire combo. Mine is the SLE model with no sun roof. I has a bit of perceptible buffeting at about 50~55 when I am in V4 mode. I have AFM turned off via my Diablo Tune...now it's smooth as silk from 0-125+. I am running 35 PSI all 4...very smooth and quiet.
adventurenali92
Big Bear Lake, ca
I switched from the factory Bridgestone dueler alenzas that were on my 2006 Denali when I bought it to Michelin premier LTX A/T2 and the difference was night and day! Love my Michelin tires.
Yukon John
SE florida
As far as I'm concerned and based on decades of experience...the Michelin LTX A/T2 and it's predecessor the LTX A/T are the best tires on the planet for a SUV or Light truck. I have run several sets of those tires on Tahoe's, GM and Ford 4 x 4 pick ups for over 25 years. They are the best...period !!
adventurenali92
Big Bear Lake, ca
Had them just about a year now. They were take offs with about 1,000 miles on them and got all 4 of them,gone $300! They're holding up quite well!!
JRLittle
2015 yukon slt 28,000 no issue so far however did experience this occasionally when conditions seemed to be just right on older ones I've had.
showtime1k
Is the buffeting related to the ear oressure
Agreed. I lease all my vehicles through my business; does not make sense owning. So I am less concerned than others about first year issues. My infotainment screen is glitchy also and it lurches hard when shifting into drive/reverse when the transmission is cold. They fixed a bad cable in the infotainment console that was causing the screen to go black occasionally.
Besides these issues, and due to the fact that I carry no sentimental value to vehicles due to leasing, I really love this truck!
is the buffeting related to the ear pressure situation. Will the afm disable correct the pressure also
Davoe1975
