Hub diameter
Modded
That Guy
Hey does anybody here know the Hub diameter on the NNBS model Tahoes, Yukons, Avalanches, Escalades and so on?
The reason why I ask is because I need some Hubcentric rings and don't feel like going to go and measure it? :hands:
Conor
"Bob's your Uncle"
Seattle, WA
If you go on discounttiredirect.com they can give you the exact ones you need and they are the aluminum ones. Dont buy the plastic ones. Last time I pirchased them was for my Acura TL and they were like $25.00
Modded
Modded
That Guy
Thanks man, I should have got them from the get go.
I don't know about you but I have just very minor/barely noticeable highway wobble/shake.
Conor
"Bob's your Uncle"
Seattle, WA
My rims are hub centric so I dont have to worry about it. But I have heard mixed opinions on the importance of the rings. I have always put them on any of the cars I have had with rims, but I have been told by shops that they are not needed and I have also heard that they are. For me, it always made me feel better knowing that everything was good and tight, but I dont think you should be getting any wobble/shake from not having the rings. Could be a balance or alignment issue.
By the way, where are the pics?
Modded
Modded
That Guy
I too have heard mixed reviews but I do hear alot that if the wobble is very slight that rigs and/or removing the stud washer would fix it, so I will try both. Rings are too cheap not to give it a try lol.
Also this is the only pic I can post for now until I fix my Cali Lean:emotions122:
---------- Post added at 12:30 PM ---------- Previous post was at 12:29 PM ----------
BTW I waant pics of yours too before you get to dropping it?
DwDrummer
AL
Don't know about your wheels but boss motorsports center bore is a 108.2!:D GM hub is 78mm!
Modded
Modded
That Guy
Yep DW mine are exactly that size ratio, now I'm just looking for the cheapest place to get them lol.
m332is
Hubcentric wheels are designed so the weight is on the hub not the lug studs. And being that it is hubcentric is spreads the load. I have raced BMWs for years with BMW CCA And SCCA Club Racing and have seen too many sheered lugs. The vehicle was designed to run with hubcentric wheels so to be safe, I get the rings which tend to be very cheap compared to what you spend in wheels.
Vince
Garage2010
