HVAC Core
Musher
North Carolina
I have a 1999 Tahoe LT and I need to replace the HVAC core, servo motors. Is there a free manual, instructions or diagrams as to what I need to do? Also does anyone make the actual HVAC core?
Welcome to the Forum from NH.
Pics of the truck, please.
Go to GMPartsDirect.com, enter your VIN, go to the Heating/Cooling section, and look for the exploded diagram of the HVAC components. You should find what you are looking for along with the correct part number. And, the cost will be significantly cheaper than the local dealer.
Also check RockAuto.com, as they also have favorable pricing for OEM parts.
east302
Mississippi
Check Rockauto for an evaporator core. The 99 GM service manual can be downloaded here, go to post #111:
You’ll need to pull the dash to get to the core. Here is how I did mine, maybe it’ll help.
Tahoe14
Central Fl
Rockauto also has a 5% parts discount, look at the top of the home page under “preferred vendor sales”.
Eman85
I guess the first thing is to explain exactly what you need to replace.
my understanding from what you posted is you want the complete HVAC module with servo motors. In the module there is a heater core and an evaporator core, both readily available. The servo motors are also replaceable and should be available also from the aftermarket sources.
bobbywdatool
