I want to go lower
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
No I am at 36 with 275 55 20
the rear is just about the same
36ish with the same 275 55 20 with 3 inches dropped
wow way to high. HOnestly just reading that I would do the front belltech drop struts even set at stock level will give you about 1.5 more than what you ahve now.
The rear belltech 3-4 inch kit with shock extenders will give you 1.5 inches more in rear than what you have now with spacer and 2.5 more without the spacer.
I TOTALLY brain farted right now but you dont have autoride on the truck do you?
J
Jimmyp19
NH
yes i do
man this just seems to get worse and worse
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes i do
lol no biggie
1) in rear do the belltech kit i have 3-4 inch adjustable springs/shock extenders/autoride links $250 shipped. Kit takes about 1 hour to put in and will get you another 1-2 inches out of the rear.
2) front since it has autoride you can do 2 things.
a) add the belltech drop springs on it which will put you 1-2 inches lower than what you have now (they are adjustable) and do the camber bushings up top which will be $260 total shipped
or
b) get rid of spinldes use stock ones and do the djm 3 inch a arm set up this will include upper/lower a arms drop you 1 inch over what you have now and will be $435 shipped
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yes itsthe strut for sure. if you pypassed autoride in front then you can do drop struts.
J
Jimmyp19
NH
ok I feel we are getting somewhere
how much for the front drop struts and
the rear belltech 3-4 inch adjustable springs
I already have the shock extenders and autoride links in the rear
do I need the djm hardware kit too?
thanks
jimmy
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
thanks
jimmy
the 250 kit comes with
springs
shock extenders
1 inch spacers.
If you separate them springs and 1 inch spacers comes to 265 shipped. You can sell the shock extenders here im sure someone will pick them up
you dont need the djm hardware kit but if you lower it fully I would cut the brackets off the frame
375 is
front drop struts
rear drop springs
rear spacers
rear shock extenders
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
sorry should have been a 4 not a 3
drop struts 215 shipped
rear drop kti 250 shipped
J
Jimmyp19
NH
I'm gonna have to call walmart and do a price check now...................
how can I pay you? You have been such a help so far, just let me pay you hahaha
jimmy
SPIS
