I'm stabbing my eyes out with this Tahoe Problem HELP!
Ephazi
I have a 2002 Tahoe, the dash cluster lights went out. here's what I've done
Replaced Cluster Bulbs
Replaced PARK LP 30a Fuse under the hood,
Took apart dash to chase shorts (Found pinched radio wires, repaired them)
Took apart steering column to see if there are any worn wires or melted relays
Took apart rear tail lights
Replaced 10a illum Fuse
Took Dimmer Switch apart, it was worn so I purchased another Dimmer
Dome light works, Headlights work, radio works, Speedo, and other gauges work. Dash lights still do not work.
What keeps blowing that 30a Fuse? I've swapped it out 10 times! Keeps getting blown. Any help would be great!
Mac
NY
Which fuse are you talking about? Park LP is a relay....
E
Ephazi
Thanks for your response... SO if it is a relay how does a relay work. All I know is when I pull the 30a out of the electrical box under the hood it gets burnd out and didn't complete the circuit.
Mac
NY
Odd?...You lost me bro....Which 30a are you talking about?
Gzes
the drifting 2dr
Wichita tx
Well there's only one thing to do. Flashlight to the dash ducktaped lol. Do you have a multimeter? Yo might be able to track the shorted wire
E
Ephazi
its the fuse in the engine electrical box. 30a PARK LP Fuse.
____
Mac
NY
Well maybe that's your problem,you're putting a 30amp fuse where the relay connectors should go.
The Park LP is a relay or switch with 4 pin connectors....not a fuse or
(circuit breaker)
E
Ephazi
switch with 4 pin connectors... Can you dumb it down for me? How do relays/4pin connectors work?
Splatmaster527
Cleveland, OH
A relay is an electronic switch that uses a small electric signal to open and close a large circuit (so you dont need the switch you actually push to carry the full load of the circuit)
What is being said is that you have a fuse in a relay slot... How likely that is I am not sure
Maybe post us a picture of your fuse box and we can check to see if thats the problem
fire730
Louisiana
If you do actually stab your eyes out you won't need dash lights any more.
Problem solved! LOL
Tssonebay
