Intake Manifold Gasket
96TAHOE215
Ok guys i have a problem my truck was losing coolant so was running fine jus had to keep replacing the coolant in the radiator so i went and got a leak dwn test truck starting running like s**t so it mechanic told me my intake manifold gasket is bad got it replaced with felpro kit but my truck still runs horrible PLEASE SOMEONE HELP!!!
96TAHOE215
no the plugs werent changed and its rough at idle and while driving could the timing be off
bsamoul
Hoe Enthusiast
Walnut Creek, CA
Are you throwing a code? When I did my gasket I put the distributor a couple tabs off on accident and it threw a code while running like crap
rd62rdstr
Tucson, Az
If its still losing coolant, it could be a head gasket. If its gotten worse, could be a cracked head at this point. Check for coolant loss again.
Zcharysch
