Intake Manifold Gaskets
colebaby
2002 Tahoe 5.3L
Changed my intake manifold gaskets this weekend after pulling a 171/174 error.
The shop tried to get me on a new fuel pump (which they claimed was low pressure), but after researching online and finding intake manifold gasket issues, I made them smoke test the intake manifold. I was right.
The shop was wrong. Surprise...
Fuel pump seems fine, but I will pressure test and watch it. Cats I will do myself next weekend, just because they are rattling.
After repair idle is perfect. I also cleaned the throttle body. The truck runs like it is brand new. MAF looked clean, so I did not bother cleaning.
I will post pictures, but there is some good information online to research.
samtman18
Yatesville, Ga
Changed mine a cpl yrs ago, wasnt bad, the hardest part was disconneting the wire terminals. Turns out it was a bad maf sensor from autozone that i changed out first.
yukondoit
Stay Classy
Flagstaff, AZ
I replaced mine in September. Like samtman18 stated, the hardest thing was disconnecting the wiring harnesses for each fuel injector. :banghead: Other than that, its a pretty straight forward install. :cheers:
Oh yeah one more thing, I had to clear the error codes after the install, but once I did that, it ran like a champ.
dwmmatt23
central valley cali
777SLK
Estonia Tallinn
do you use silicone with new ones?
have mine allready installed without silicon and now thinking.. long term is high.. no CEL by the way
ktmhans
Connecticut
I forgot the part # but if you search my threads one of the members posted the # for the nock sensors and an updated wiring harness for them. My biggest pita doing this was just popping off the gas lines.
bkboatnsleds
McHenry, IL
I didn't do that video yet.. sorry :( No, I wouldn't use any Silicone anywhere.. With the right tools those gas lines should literally pop off.
---------- Post added at 09:50 PM ---------- Previous post was at 09:40 PM ----------
I wouldn't use silicone on the INTAKE gaskets.. is what i mean..
Civcomm
