Intermittent Braking Loss on '16 Yukon
Yukon John
SE florida
I have suddenly experienced occasional "Dead Pedal" at low speeds and when stopped on a hill either headed up or down an incline. I did a bit of research and learned that there is a TSB for 2015~2017 Full Size GM Suv's that address this condition. Seems that the fix requires replacing the vacuum pump, brake booster as well as the master cylinder, etc. I am still under the drive train warranty and am wondering if anyone on the Forum has had this issue and taken their truck into a dealer for the repair/correction?
#PIT5361B: Diagnostic Tip - Additional Brake Pedal Effort - (Jun 28, 2016)
Subject: Diagnostic Tip - Additional Brake Pedal Effort
Models: 2015-2016 Cadillac Escalade Models 2014 Chevrolet Silverado 1500 2015-2016 Chevrolet Silverado 1500, Suburban, Tahoe 2014 GMC Sierra 1500 2015-2016 GMC Sierra 1500, Yukon Models
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern
In some rare situations, a customer may comment on a hard brake pedal or that increased effort is needed to depress the brake pedal. Also, in some cases a tick or ticking noise may be heard, which may sound like an exhaust manifold leak. While performing normal diagnostics, fluid may be found in the brake booster and/or the booster vacuum line.
Important: Pay close attention to the fluid and if it is determined to be engine oil, it could be coming from the vacuum pump. The vacuum pump is belt-driven and mounted to the side of the engine block. It is lubricated by pressurized engine oil.
Recommendation/Instructions
Ifengine oil is found, it is important the following parts are replaced. If not, the condition will return.
  1. Vacuum Pump
  2. Vacuum Line between the booster and the pump
  3. Brake Booster
  4. Master Cylinder
  5. Vacuum Pump Belt"
Thanks in advance.
that sounds like a really bad design, I wonder what happens when the vacuum pump decides to completely blow the seal and send a surge of engine oil into the brake booster.
why is the vacuum pump even designed in this manner? there should be no possible way for engine oil to get into your brake system
Bai2020
Yes, we had this happen in our 2016 tahoe... twice. The first time at around 30k miles and the 2nd time around 33k miles. We're now at 40k miles and haven't had any issues. For us, it would only happen at very low speeds in scenarios like being in a line of cars at a stop sign where we would constantly be applying brake pressure then moving forward slowly. Luckily never at high speeds. Scary though when you're in traffic moving slowly and have to almost stand on the brake pedal to stop. I believe the entire list of parts was replaced each time. Not sure why it failed a 2nd time, my wife almost wanted to trade in the car, obviously a serious safety issue.
Yukon John
Yukon John
SE florida
Thanks for your reply....I will get in touch with the local GMC dealer tomorrow.
Yukon John
Yukon John
SE florida
OK...remember the old expression " The pen is mightier than the sword" ? Soooo...while I was waiting in the "Customer's Lounge"...I called GM Customer Service and explained to them what was going on. The young lady with GM put me on hold for a few minutes while she verified my VIN and odometer mileage (On Star)...got back to me with a call transfer to a "Customer Service Manager". The CS Mgr gave me a case number, called the dealer while I was on hold...came back on the line and told me there would be NO CHARGE...and I should go back to the service department. Before I could get across the building...I heard my name called out on the PA system to please report to the Service Department. I was met by my service advisor and the Service Manager confirming what GM Customer Service had told me...the repairs would be handled under warranty for Engine and Drivetrain at No Charge to me.
Lots of smiling faces and hand shakes later...within about 2 hours I was on my way. Oh...they also gave me a discount on a full 8 quart full synthetic oil and filter change fo $60 !!!
GMC Truck Division...HELL YES !!!:head3:
Miami-Dade
I am definitely going to your dealer for my next service as soon as I get off my road trip in the next couple of weeks. My present dealer Schumacher Chevrolet-GMC on North Lake Blvd in North Palm Beach is horrible.
dbbd1
Don't forget, that was after the GM phone call. Of course they are going to be nice, after they get spanked by daddy GM.
tony97218
