Issues with my rear axle housing
99Yuk
Northern Ontario, Canada
LOL..
Well, we are going to see if one of you guys Really VOODO my SUV..
going to send this SUV back to the Body shop for another 3 weeks of body work and paint..
after its finish, going to replace that two tire with a USE tire, then Wheel alignment.
After that going to install the Steering stabilizers.
And Install the Wheel Spacer.
Lets see how the SUV looks and fell after all this mod is added.
I'll bet it'll be much better!
beamer
beamer
Brunswick, GA
Update
OK all...
Here is th final report !
The rear axle assembly WAS BENT. How the heck they did that, I don't know.
My son was driving it in the neighborhood and the left axle slid right out also. Like there was no C-clip in there. It didn't break, the axle was fully in tact, just had the splines roughed up a bit as it slid out through the tube and smashed up against the bearings. When I opened the diff cover, I did not see a clip in there, but could have came out with fluid and I did not realize it.
I called the salvage yard and they were saying that there was no way that it just came out, and that we must have broke it. When I got there Saturday morning, they saw that it was in tact and said OK, put it over there and I have another for you. I then compared the two and obviously saw that the one pulled out was bent compared to the other replacement thay had waiting for me. I replaced the axle seals and I know for a fact that the clips are in there, the pin is in and the rear is full of fluid with a bottle of posi fluid.
I hope this is good for a while !
BTW, my tires are ruined from the 350 some miles put on that rear end, as the insides are wore flat out from the bent axle.
Thanks for all the inputs !
Mike
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
Now that you got good stuff under your truck hopefully you're good to go from here on out. At least it sounds like the junk yard was cool about it.
:happy160:
hosleyb
