It just keeps getting better and better......
Stresst
So I got my truck back mid last week, the first day I got it back it was blowing a tad under 40 degrees. By friday it was 45 degrees, didnt use the truck saturday or sunday and guess what? No friggen a/c this morning. Brought it back to the shop, got a call about 1 hour later. The 2 lines that run fron to rear are all corroded! List from the dealer almost 360.00 and from what I hear a PITA to instal. I wound up buying high pressure rubber hoses should be here wednesday. WHAT THE EFF???
Diller
Cedarburg, WI
Unfortunately that is a common problem with these trucks. I'm a bit afraid to see if that's what is wrong with my '99 also.
Administrator
wow....this is an expensive month for you man!
ghoster
Baltimore
At this point.... with the luck you have had so far, I think I would be pricing out the entire rear ac unit. That is about the only original thing left isn't it?
S
Stresst
I actually bought the lines from autocoolingsolutions.com, great customer support, will have a better review once the parts arrive. Supposedly you dont have to remove the running boards with these lines and old line which in turn saves a ton of labor. Allegdly these last much longer then factory lines as well. Hopefully everything goes as easy as said........Yes this is getting expensive fast! :(
Jeremytahoe
