Jonas's 79' CJ7 Build.....
Yuko04
Yuko04
"SquareBODluvr"
MN
^^^Thanks my man[emoji106]
Jiggy-J
Yuko04
Yuko04
"SquareBODluvr"
MN
Got it up on the dollies we made, pushed it outside and did some cutting and grinding. Getting it ready for the portable sandblasting company coming to the house next week.
Jiggy-J
THE YETI
Director of Operations
South FL
What's all that white stuff on your grass?
08grey
Por 15 that bad boy when your done blasting and it will last forever.
Yuko04
Yuko04
"SquareBODluvr"
MN
You know what that is boooooooy!
As per Jacob and everyone else has giving the POR15 a double thumbs up...
Thats what i will go with.
Put it in my gun and go to town.
Jiggy-J
Yuko04
Yuko04
"SquareBODluvr"
MN
DAY 7: Get frame blasted and ready to cut,grind and REBUILD!
Portable Basting company came to my house today and blasted the frame top and bottom for $90. Best money I have spent today!!
Well Russ is a dedicated guy. After an ice storm last night....he was still on time.
You can see the difference between left and right already.
Guess the sand WON on this frame rail.
ALL DONE AND DRIED OFF!
Here is the 4x8 Sheet of 3/16 steel that I will be using to put into the frame.
I will Plasma cut each template I make and weld it in.
I cheated an bought the rear frame rails and cross member. Got to cheat somewhere:)PC084709_zps1ebd1d12.jpgPC084710_zpsc3151125.jpg
Now to start boxing in that frame!
Administrator
$90???? :eek: That's even cheaper than what we talked about on the phone. wowzers!!! :waytogo:
Man that frame must have spent it's entire life in Minnesota! You have got your work cut out for you man! :popcorn:
Yuko04
Yuko04
"SquareBODluvr"
MN
Yeah It was cheaper than we said. He says it depends on the frame. I gave him a $10 tip for lunch. Jeep is actually from Ohio and then titled in WI 3 times and then me.
I do have my work cut out for me,but this where you see the skills of "SUBLETT KUSTOMZ". LOL!
p.s There was a mouse nest in the frame rail itself. When he put the sandblasting gun in the end. Insulation and dryer sheets flew out. We both started laughing!!!
FRANKLYN63
