jus ordered 2006 vette z06 assembled heads and cam,lifters,push rods with comp rock
t_ahan
t_ahan
Crofton, Md
ls7 top end didnt work
well the ls7 heads didnt work due to valve to block interference....i would need to have the block bored out...so instead i exchanged for ls2 heads which will slap right on!! and yes i had to change the cam and get other rockers and push rods for the ls2 top end setup
AquinoSteven
Key and Spacer Guru
Clinton, NJ
The intake off the tbss or the newer 6.0s work well. People have seen gains of up to 10hp on stock trucks.
KrautBurner
Bremerton, Wa
damn,
I'd exchange some LS2 heads for those ;)
t_ahan
t_ahan
Crofton, Md
Doing install!!!
got around to actually doin the build and got a trans to go in with the new set up! build pics on the way!! may be in other threads
t_ahan
t_ahan
Crofton, Md
c5 killer!!!
Set up ran great and ended up doing FAST Intake and 80mm bbk tb ,ealge rods and diamond pistons and got about 4500 miles out of the motor till I pulled it back due to loss of compression in 6 cylinders....but with the 2500 stall trq.con. and the level2 performabuilt trans the truck ran strong n surprisingly fast and proud to say it drug every1 i could find down the local streets! ! I am now looking for a bigger throttle body and possibly.030"over bore to get more! Any info on drive by wire throttle bodies would be great! And thank u to the members for all the info that's on this site
t_ahan
t_ahan
Crofton, Md
motor build pics
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
t_ahan
t_ahan
Crofton, Md
more pics
attachment.php
attachment.php
attachment.php
attachment.php
NathanJax
Vacation Nathan
Administrator
Jax, Fl
Nice motor
(I helped fix the pics. Not sure why attachments some times show up weird)
Dman816
