jus ordered 2006 vette z06 assembled heads and cam,lifters,push rods with comp rock
FreshLikeOprah
wow, i wish I would of seen this before you wasted your time. Of course LS7 heads wont work. They won't fit anything less than a 4.125bore. MAST motorsports makes small bore LS7 heads. I'd definetley go with a 90mm TB from a TBSS or LS2 car. That 78mm is restricting you some. You'll need to get a "X-Link adapter" to work. They're about $200 (you can find one used) Are the heads stock, or ported? What cam you running?
---------- Post added at 07:52 PM ---------- Previous post was at 07:51 PM ----------
TBSs or LS3 TB or a Ls7 TB. But still need a x-link adapter. You're not running boost, so you won't have any issues, but the car TB's open up backwards and some guys lose power when running boost.
Z-56 Hoe
What do I do????
Houston
LS2 throttle body works great onmybuild I had to get that adaptor harness from Texas speed tho.
Dman816
