Just Fishing
Can't fix stupid
And for the grille screen retainer.
For the most part i was able to push the screen out in order to lock it in place.
But for the wire retainer part, this is what i did.
The trick is to not crack the screen through.
a little trial and error for me.
I ended up picking a thicker place in the screen for the wire, since thinner ends broke through way to easily.
One thing i was unsure of, how much space for the wire would i have when the grille inserts are reinstalled.
Answer = plenty of space.
I went back through the lower insert to brace it a little better.
The top screen also helps to block access to the hood release, as i found out earlier how easy it can be opened from the outside of the truck.
Now of course you can still just jab a screw driver through the screen, but it will leave a very obvious mark.
