K5L cooling fans
There is not a 9/9 setup, something to do with harmonics or something like that. I could also be mistaken about which side the fans go on and confused that with relay activation and wiring.
you are probably right because I think if anything was going to have a 9/9 it would be the hummer and it only showed 7/9
St. Louis
I was just going by the part numbers James listed above.
K5L 700w motors are same part numbers as 6.2l 9 blade motors
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
From the shop manual:
The electric cooling fan assembly uses a 5-blade fan and a 7-blade fan. It does not matter which side the fan blades are installed on. DO NOT install two 5-blade assemblies or two 7-blade assemblies, as this would cause a noise issue.
B
BrainDead
Thanks for all the info guys, I'll take a look tomorrow and count the blades. If I need to I'll pick up the one that doubeilve listed and the new motors for cheap insurance
Raynii054
