Send an email to @BlackBearPerf and ask if they can do it for you. A blackbear tune will cost ~$500, but they’ll also tune your engine and transmission for better performance, and if you decide to do other mods later like a cam upgrade, they’ll tune it for you for free. I’m super happy with my tunes from them.Any idea who to contact to get the computer to turn the fans on at a lower temp at speed. Can I do that with a tuner or is that a special tool.
Thanks so much, we would be happy to help with a tune! Tune prices vary depending on what option you go with. Also we had to change our free update policy for the first time ever since opening our doors. Tune updates are free for the first year, after that it would be $40 to $150 depending on what type of mods you are adding.Send an email to @BlackBearPerf and ask if they can do it for you. A blackbear tune will cost ~$500, but they’ll also tune your engine and transmission for better performance, and if you decide to do other mods later like a cam upgrade, they’ll tune it for you for free. I’m super happy with my tunes from them.
Say what!?! You guys just lost business on that deal. Only kidding, definitely check out BB for a tune, they will get you dialed right in.Tune updates are free for the first year, after that it would be $40 to $150 depending on what type of mods you are adding.
Also, if you don’t already have one, consider looking into a Tech2.Any idea who to contact to get the computer to turn the fans on at a lower temp at speed. Can I do that with a tuner or is that a special tool.
*Bump on this post. Do we have p/n’s for these in case others come looking.Do you think the mishimoto works better than the factory radiator?.
Your pro’s seem counterintuitive to the list of cons. Haha.I installed a Cold Case
Cons:
1. Lots of grinding and bending to make it fit.
2. Required cutting fan shroud
3. Very poor manufacturing the fitting on the trans cooler would not seal and they sent me an external cooler that runs as high as 250 degrees.
4. Need to make a restrictor for the coolant tank line
5. Triggers engine failure codes.
Pros:
1. It does cool the motor better
2. It has a drain on it that works
I actually will replace it with a stock one next time.
Yes it is still on there for now, I am going to try and get the radiator cooler to stop leaking and if that doesn't work it might be time to get a new radiator or see if Cold Case wants to warranty it.Your pro’s seem counterintuitive to the list of cons. Haha.
Was that Cold Case installed on your 11’ Hoe?
