Keeping coolant and transmission temps under control when towing in the summer heat
Sparksalot
Bastrop County, Texas
Usually the aluminum case ammo doesn't have a typical type reloadable primer (Berdan vs Boxer). It's still removable, but would probably just need to be drilled out.
Exactly. I’ve been trying to remember if I’ve ever seen it in 45. Usually ive seen 38 and 9.
alpha_omega
Michigan
Your pins and springs might eventually care. Unless you’re shopping something other than a Wilson Combat, Kimber or MEUSOC .45, in which case fire away.
Mreedini
