LED dash pics and specs and crap
drowndindreams
Unknown
re-did mine just now. i had a breakthrough while doing it lol. some of the bulbs werent working so i had to sacrifice some out of the doors. anyway i also threw in a 8-led light that is used for the dome but can be hardwired into a 194 bulb. before and after pics!
the big blue bus
richmond, va
looks much better man! im so glad half of the interior bulbs are the same. i was missing a courtesy light on drivers side and i used one of the corner light bulbs since i switched to clear corners also put the other in the 4wd indicator for now. will do leds eventually once i get exterior the way i want. would like a blue coated 194 bulb look good instead of a led for now?
drowndindreams
Unknown
eh thats more like a bluish white sort of bulb, i remember i bought two of those for my dome lights thinking they would be the same as leds but theyre nowhere near as bright
the big blue bus
richmond, va
yea i got them to try em and they arent that bright well i cant ge the bulb on the passenger side out but got the drivers side in. just seeing that lil blue color makes me want to replace all of the lights in the doors too and roof lights now. i want to do the doors with white leds along with the other interior lights besides guages and ac controls. which leds to yall recomend for the doors and everything
the big blue bus
richmond, va
would the regualr wled 120 degree bulbs from superbright led work allright for the doors 4wd and under dash? also what bulbs did yall get for the dome lights?
Devious_Tahoe96
Mr. Budwieser
West Texas
Yeah the ones in th cluster will fit the ones on the doors, which are the 194 bulbs. The bulb number is 211.
the big blue bus
richmond, va
i know they are same size as cluster. im going to get nicer ones for the cluster to avoid hot spots but i was thinking just the basic ones for the spots i mentioned. which bulbs did yall use there
the big blue bus
richmond, va
would these bulbs work for under dash doors and 4wd? http://www.superbrightleds.com/cgi-bin/store/index.cgi?action=DispPage&Page2Disp=/specs/WLED-x.htm
i want to order them soon and need to know. dont know if i need to buy the wled5s to get a better look. wil the ones posted above look good in doors? they wil only cost me like 12 for all 8 or should i go for the better ones? if i should do better should i get cool white or natural? and would it look good with blue in doors and underdash too? or should i just stick em under dash and do white everywhere else besides in dash?
Devious_Tahoe96
Mr. Budwieser
West Texas
the big blue bus
richmond, va
are they going to be bright enough? hey are rated at 3 lumens while others are like 10 . dont know if i should buy the cheaper ones for like 11 bucks or the 5 led ones for like 30
haileyds
