LED DRL Questions
2010_5thgen
Ebstores is his user name. And yes I got all my lights on eBay. 6,000k hids and bright white led lights
Stresst
eBay. Eb stores is the guys member id
---------- Post added at 07:55 AM ---------- Previous post was at 07:52 AM ----------
Headlights and brights are 2 different bulbs. If you want hid as brights, you need a different set. As far as the drls, those are not the headlights. The drls, assuming you talking about a newer Tahoe, are the lower logs under the headlights. Can't tember if they were the inner or outer set.
My HID's are on all the time.....as far as brights go what number bulb is it?
2010_5thgen
What do you have a Yukon or Tahoe? If you have a Tahoe they're two separate lights. If you have a Yukon it should be the same light and it wouldn't be that your brights are on all the time it's just that the H IDs are that much brighter Then the halogen bulbs that were in there. If it shows that your brights light is on your dashboard then you hook something up wrong
Stresst
2007 Yukon. No it doesnt show that the brites are on but when I put them on its not the HID. If its not raining tomorrow morning I will take some pics when I get to work.
2010_5thgen
Ok so your hids are on. No brights though. That's what's happening. You only have low beams in your lights. They make hids with high beam halogen or hid. Yours are just low hid. That's how my hummer was. Don't worry about the high beam. It's too complicated to get hid high with your setup. In my opinion. The hid low and halogen high is a simple kit but the halogen lights suck.
Rkelly1224
