Lifted/Leveled 2021 - Postem Up
ProfeZZor X
High Country
It’ll crank up to 4.5” but I think that might be a lot.
This is what it looked like on a customer build. 24s on 35s
I have the Ready-Lift 3" SST lift, and it's the right amount of lift for me without compromising parking garage clearances. with 33's and the 3" lift, my height comes in at around 6'6".
Hunter Linn
Tuscaloosa, Alabama
Hey Guys,
I just ordered the RC 3.5" lift and 35x12.5x20 tires. I want to use it on my stock Z71 20" wheel. Do any of you know what size spacers I will need to prevent rubbing UCA, inner fender, ect. I do not want them to stick out far. Just enough to not rub.
STORMIN08
i would do the thinnest bolt on specer you can get...1"
i have seen 1.5 and 2, both protrude more than i would care for. i like to mine to be covered by a STREET FLARE if needed, so no more that about 3/4" out of the fender.
Hunter Linn
Tuscaloosa, Alabama
Thank you, I’ll go ahead and order that too. Hopefully I’ll have it all on in the next week or two.
nick14226
Would check how deep the pockets are in the wheels you have, your studs are going to stick out a decent amount with 1” spacers (unless you’re willing to trim them).
I’m running 1.25” bora spacers and they clear but it’s close without stud trimming.
Hunter Linn
Tuscaloosa, Alabama
I was looking at running the 1.25" Bora spacers as well. It should fit. If it does not, I have no issue with trimming.
nick14226
With that said I’m only talking the studs, only assuming the 1.25 are enough to clear UCA’s. And think you’re going to have a decent amount of fender work to fit 35’s.
Scpori
