Low Oil Pressure at Idle When Warm
A
Austen Leach
Well, you replaced the o-ring and checked the pressure sensors and oil filter. Have you filled the motor with 8 or 9 quarts of oil and seen what the pressure is?
I haven’t actually checked the pressure sensor. Is there a way to do this? I also have not put 8 or 9 quarts of oil in it. Wouldn’t that just tell me if the pickup tube o-ring was bad?
I thought you had swapped it out. The other way would be to view data from scan tool and compare to dash and then of course a mechanical gauge. As for the o-ring, yes, over-filling would submerge the o-ring and eliminate starvation if it was pinched or rotten.
A
Austen Leach
The Solus I have won’t read actual oil pressure so I can compare it to the dash but it does give me oil pressure switch voltage which is sitting at 1.41-1.52 with the dash showing oil pressure at 30psi and coolant temp at 158 degrees Fahrenheit
That sender voltage tracks with mine ('04 5.3 Flex):
Gauge Oil Sensor
Pressure_ Voltage (v)
0 (engine off) 0.53
35 1.69
40 1.86
45 2.06
50 2.29
60 2.41
That doesn't mean that your sender isn't under-reporting the actual oil pressure, though. Only way to verify that is with a direct pressure gauge.
A
Austen Leach
Gauge Oil Sensor
0 (engine off) 0.53
35 1.69
40 1.86
45 2.06
50 2.29
60 2.41
I’ll double check the voltages tomorrow. I’m trying to do all the diagnostics I can until I can afford to get a mechanical gauge or just replace the sensor
bondservant2
is the o-ring problem an issue on the later (07-13) 6.0 engines..? I’ve always thought my K2500 should have better oil pressure. About 20 at warm idle. I haven’t owned a GM product for years and this one only a few months.
wjburken
Eastern Iowa
Yep.
Dwzy1223
