Bigbertha78
- Joined
- Apr 4, 2015
- Posts
- 159
- Reaction score
- 24
I will find out on Monday. What do you think it might be? Thanks
Pull off the intake tube and clean your throttle plate on your throttle body. Use carb cleaner or brake cleaner sprayed onto a rag and wipe the plate and the bore.
From your symptoms it will probably be pretty black around the edges of the throttle plate. You can spray carb cleaner directly onto the throttle plate and bore as well just make sure that if you do, try not to get too much into the intake behind the thottle plate as it will have a harder time starting when you crank it over. If it does have a hard time starting just depress the accelerator pedal a bit while cranking to allow the throttle plate to open and let more air in. Once it starts up release the pedal.
