Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
bottomline2000
Dallas, TX
Let’s hope valve train and cam is top notch.
Not to hijack, but to add to this build so if you decided I'll leave it at that..
Not to scare you or anything but a lot of guys were complaining about failed ls7 lifters a few years ago. I avoided doing lifters with my cam swap and I regret it now since I had the stupid things in my hands and didn't want to risk it. A lot of them were Vette guys and I think there were some defective heads that led to their problems and some cams with bad lobes and race specd cams so overall I don't think it was the lifters.
I'm curious which ls7 lifters you get since BTR sells them but I don't know which ones are the genuine GM ones. @67427ss is running them and his engine sounds great. I'm thinking about ripping my heads off and doing mine.. only issue is they have like 3 different ones listed ranging from $99-over $200..for Morels..
Sent from my SAMSUNG-SM-T377A using Tapatalk
Chrismnj
Chrismnj
NJ
Here is the kit I got, I believe Matt has the same one. I don't know enough about lifter failures so can't help you with that, will tackle when it comes. It’s best to give BTR a call they will make recommendations. Thank you for head up.
bottomline2000
Dallas, TX
Thanks, yeah I have the trunion upgrade. That's for the rockers. Good luck with the trunion upgrade..******* the fingertips lol..
Chrismnj
Chrismnj
NJ
sorry wrong box, have them at the mechanic shop already. So you don't recommend changing them?
Chrismnj
Chrismnj
NJ
Correction, didn't even get them yet. Ordered them last week along with the trays, too much going on at once lol
Chrismnj
Chrismnj
NJ
DELPHI LS7 LIFTERS (set of 16) X12499225-16
Chrismnj
Chrismnj
NJ
1. Magnacharger TVS1900
2. BlackBear Tune
3. Airaid 202-270 AIRAID MXP Series Cold Air Dam Intake System
4. Kooks Y-Pipe 28553200
5. Kooks Longtube Headers 28502400, *ceramic coating
* Magnaflow exhaust already installed
6. Moroso 85481 Air/Oil Separator
7. Auto Meter 17118 Triple Pillar Gauge Pad
8. GlowShift Black Gauges
9. Accel 9070C Extreme Ceramic 135 degree boot Plug Wires
10. AC Delco 12673134 Oil Pressure Sensor
11. AC Delco Ignition Coil D513A
12. ACDelco 12617944 GM Original Equipment Exhaust Manifold Gasket
13. Stage 8 8900 Locking Header Bolt Kit for GM Small Block
14. NGK Spark Plugs BP7EFS/3526 - NGK Standard Series Spark Plugs
15. BTR POSITIVE DISPLACEMENT SUPERCHARGED STAGE I CAM FROM CAM MOTION, CM32338206
16. .660" Lift BTR Platinum LS Spring Kit; Titanium Ret., .505" ID .060" Thick Loc., Black Seals, SK001/T/0560/BB
17. BTR Chromoly One Piece Pushrods; 7.400" Long, 5/16" Diameter, .080" Wall, Set of 16, PR7400312-16
18. BTR GM LS ROCKER ARM TRUNNION UPGRADE KIT TK001
19. CAMSHAFT INSTALLATION KIT
20. COMP CAMS TRUNNION TOOL FOR LS ENGINES; CC54702-TL
21. Hummer GM OEM 08-10 H3-Engine Motor Mount Torque Strut 25847739
22. PATC Transmission Pan, GM 6L80 / 6L80E, Deep As-Cast
23. Circle D GM 265mm 2500-2700 Stall 3 Disk lock up Pro Series 6L80 Torque Converter
24. GM Lifter trays non AFM BTR95365-4
25. Delphi LS7 Lifters X12499225-16
26. BTR Head GasketBTR17944
27. BTR LS Head Bolt kit BTR00568
28. BTR LS Multilayer head gasket BTR22033
29. Valley cover 12598832
30. Basic VVT Delete kit VVTBASIC/A80
Mrfirewolf1000
