Make my 5.3 sound like a 6.2. HELP.
totheyard
If part #1 is 3.5in, then the flange will probably not fit the 5.3 exhaust manifold. I would look for you, but the wife has the truck.
Blazed
Accepting Donations
And well I'm pretty sure the flange size above the cats is the same but if you could check for me when you the car that would be fantastic!
07whitetahoe
The manifolds between the 5.3 and 6.2 are different. Pretty sure it won't bolt up, 5.3 has 2.75" tubing behind y-pipe, 6.2 has 3.5".
Just have a shop weld in a flo-pro big oval muffler that is slightly louder than "stock sound"muffler. PN 2510 is a 3.5" in and out, used on NNBS 6.0 and 6.2 trucks. A muffler shop should be able to make adaptors to go from 2.75" to 3.5", plus it will be TONS cheaper than what sounds like you are working on
kses123
kses123
Raleigh, NC
Yes, the manifolds are different, but the connection at the manifolds is the same on the 5.3 and 6.2.
Goodinblack
Goodinblack
I Like Tacos
Dirty South
Kses123.........Is the Amsoil filter you are using reusable/washable like K&N's?
kses123
kses123
Raleigh, NC
No, it is not. That is why I got it. I just didn't like how messy and oily the K&N one was. The amsoil one didn't cost very much either, so it doesn't really bother me.
Blazed
Accepting Donations
So kses your sure the connection at the manifolds is the same?
drackill1
