Melted mega fuse holder near positive battery post
DaveO9
Vancouver, WA
On a long road trip, taking daughter to college. Within a few miles of final destination tonight, smell burning rubber. Turns out the load side bolt on the mega fuse holder was loose, thereby causing arcing at that connection and generating a lot of heat. It melted the red cover, but more importantly, damaged the plastic holder so the head of that bolt is no longer captured, making it hard to tighten. I did eventually get it to torque down using a wrench on the back side where the head should be socketed into the plastic. Of course I will need to replace this piece but I don’t think I’d be able to get it on the road? Is that going to be a dealer part? I’ve looked briefly on RA and Google, not finding it yet. I think what I’ve done will get me home, but just checking if there’s any input.
At first I thought I blew the mega fuse, there is some visible damage. But everything seems to be doing fine now. I will buy one before my wife and I head home to have with me just in case.
solli5pack
Looks like it comes with the battery cable. #22790285. Need to verify with your trucks options though. They're probably plentiful in junkyard.
DaveO9
DaveO9
Vancouver, WA
Cool, thanks for finding that! I’ll just get the whole new cable. Pick-n-pull around here doesn’t have any NNBS yet. NBS is about as new as I’ve seen.
that bolt shouldn't be just "loose" it could have got hot and melted some therefore making it loose...
might want to poke around with a meter on the grounds and see if one or more are high ohm's just to be on the safe side.
theoretically though the fuse should have blown versus melting the connector......still could be a high ohm situation
the starter cables/ground is often a culprit
OmarRa
