Minor performance mods help.
Sandaman
Sandaman
U.A.E.
Out of those two, I'd go with the Docooler. Add one of these to it:
You set it on top of that round plate with the holes in it.
Yup.
Will do this by end of month + 2inch level in front. Ill do muffler later. Might cost me like <200 I hope. Waiting for pay day.
BTW which leveling should I do. The shock spacer that goes on top of the shock absorber or the one that goes below shaped like a C.
TY
TY
Both accomplish the same thing by the same means. The one that goes at the bottom, between the lower control arm and strut crossbar is cheaper and easier to install. I did mine in about an hour. There are resin ("plastic") ones and billet aluminum. I've never heard of the plastic ones failing, but I felt better about the billet aluminum. I got a cheap set off ebay or Amazon for around $20 and grade 8 bolts from the hardware store cuz I didn't care for the cheap-looking "grade 5" bolts that came with them. It's just a chunk of aluminum- the expensive big name versions are all the same, just with their company logo engraved into them. Measure your Tahoe first to determine what lift you need to level it. They're available in 1", 1.5", 1.75", 2" and 2.5". Personally, I wouldn't go over a 2.5" with this type of spacer lift.
Sandaman
Sandaman
U.A.E.
Think ill go for the 2'' lift. and remove the lip below the bumper.
TY for ur advice. Im getting so much help from you.
Sandaman
Sandaman
U.A.E.
The lifting shop said I have 2 options guys @gooffeyguy
1. Get a spacer lift front (spacer made of teflon) price - 137$
2. Get a coil spring lift (all around) price - 273$
Both include fixing charges
Any advice on what I should get.
TY
TY
So those are spacers for a front and rear lift?
I assume that's UAE dollars? If so, that's a great deal including labor!
Sandaman
Sandaman
U.A.E.
I converted the price to American dollars. haha
Just lift in front
lbtahoe
