Mirrors fold when key out
Rivieraracing
Very very nice man, talk about a quality install!! So, I assume that not only do they fold now, but also you were able to get the auto dimming, signals and heated features to work as well as powered glass movement?
---------- Post added at 05:55 PM ---------- Previous post was at 05:54 PM ----------
Just now saw the video, that answered my signal part of the question!
01 Suburban LS
Yep, it all works.
Kman
Southern California
I want to do this so bad.
---------- Post added at 04:15 PM ---------- Previous post was at 04:12 PM ----------
You can also add power folding mirrors to 99-02s as well. I did it on my 2001 Suburban. You'll need a 2002 Escalade power folding mirror switch and to do a little wiring.
The mirrors came out of a 2006 I believe and as most of you may or may not know, the electrical connectors are different. So instead of just cutting and splicing wires, I purchased some OEM connectors and made the 2006 mirrors plug and play into a 2001.
I refered to this thread for the wiring:
http://www.gmfullsize.com/forum/showthread.php?t=200970&highlight=fold+mirror
Here is a short video of them in action:
http://youtu.be/MQNayJdX9rk
How difficult was it to wire up the mirror turn signals into your 2001? Looks great btw!
chevy1500
yo
where can i find that switch and plug that goes behind it ? i have everything working except for the folding and also do u have traction control
magicbus
Wichita Falls, TX
I'm a little late to this party, but I found this thread while looking for info to add dl3 mirrors to the wife's 02 Yukon. I should be installing my ca671 in my 05 XL with the dl3 option and might attempt either folding with key off or just via auxiliary on the alarm. Either way, I might attempt wiring into the switch contact in the driver door module and isolating with a diode. Doing this I will eliminate the extra cost and wiring of timer relays and such; also using he factory controls so they work exactly as intended from GM. Basically it will work off of the switch instead of supplying power to the mirrors. I would not recommend this to anyone who does not have extensive soldering skills using precision irons on circuit boards and such. I will bring an update if/when I do it and whether or not it works.
OmarR
Indianapolis, IN
I definitely wish you luck on the project! Take pics and post up!
you know thats why alarms have a parking light output, for visual confirmation and they also chirp...
And I am not trying to be overly critical but I have installed alarms solid for 20+ years and there are ways of confirming your alarm is armed instead of having your mirrors fold in, just saying
There are different unique ways for visual confirmation; mirrors in/out, airbags dropped/raised, etc. If you are implying that there is a right way and a wrong way, well that is simply not true.
If that is not what you were implying, than I really don't know what your point was.
magicbus
Wichita Falls, TX
I will for sure, its looking now though that it won't be this weekend, and I might end up finding another door module to try it out with so I don't ruin my current one.
Sounds to me like more hate and jealousy of people who go above and beyond to do the quirky things we want to do.
Jongrreat
