more lift ?
the big blue bus
richmond, va
how much is it cranked now? could get a lil bit more lif tbut not much and a slightly bigger block. but theres not many other options without swaping the lift out and the 3inch bl.
preshus
preshus
washington,IN
ya im not sure if its cranked or not . . . i mean it feels pretty stiff but yet
soft so im not sure il find out sometime this week when i get it back . . .
if i get a good deal on this set of tires and i need another inch to clear them
then il crank it more and add a 3 inch or 4 inch block whichever and i think
that should be fine if not il just get a size smaller lol . . . i didn't realize
how complicated it would be to lift it alot higher
bowtiefreak
No Quarter
Near Philly
your chasing your tail here. Cranking and a 3-4" block isn't going to give you what you are after. You might....might be able to get 1-2" up front on that truck, that's it. Get us a picture of teh front set up so we can see the angles as well as the set up for the rear.
This will tell us what you can get out of it
preshus
preshus
washington,IN
alright man il do that as soon as i get my truck back . . . the way i
understood it was you crank the keys and it
raises the front and i figured i would just go with a bigger block on both
ends to keep it even may not even need to crank it . . . what i need to do
is take it to big o and see how big of a tire i can fit under it and how much
higher i may need to go and just basically build my basis around the
tire . . . i may not need it at all but id still like it to look lifted and have
room and not be hugging the tires you know what i mean . . . i just got
confused in one grate big mess with this hole deal lol . . . il post some
piks up soon as i can and do some searching online some more . . .
thanks for answers
---------- Post added at 12:52 AM ---------- Previous post was Yesterday at 11:54 PM ----------
or maybe see what i can get out of the front like you said maybe 1-2 inches and
just swap out the block in the back to even the truck . . . that would be cheaper
wouldn't it but also make it ride harder right
purple 'hoe
Green Bay, Wisconsin
I've just been catching up with this thread, but are you talking about adding a 2inch lift block in the rear or are you talking about buying a bigger lift block?
Either way, oh my. Just shackle flip the rear and buy some lift springs if needed. Don't use blocks that tall. And whatever you do, DO NOT STACK LIFT BLOCKS.
bowtiefreak
No Quarter
Near Philly
Lifting the back isn't going to change the fact that the front can't go much higher without new kit or complete change of suspension up front.
preshus
preshus
washington,IN
completely understand no stacking . . . heres what i thought was on my
i thought this is how the setup was suppose to be . . . you got your suspinsion lift
on and then you got 2 inch blocks on the front and the back right that
is the only way that makes since to me . . . what i was tlking about
was swaping out my blocks for a bigger one to clear big tires . . . im
almost positive i can clear 38s or 39s easyily but if i get this deal on
a set of 40s then i wanna add bigger blocks on my truck instead of doin
anything to the suspinsion lift . . . or a shackle flip becouse that only
lifts the rear end right . . . i don't know how this thread got so confusing
lol
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
so i can't add a bigger block up front to go higher
992door
Greenville, NC
As it sits right now i know you can clear 37's. That is what he had on there at one point
37's
preshus
preshus
washington,IN
37's
ya thats what i thought he said he had on it at one point and that pik
looks really good
---------- Post added at 01:47 PM ---------- Previous post was at 01:44 PM ----------
i really like the look of the baja's but i would love to see what boggers would look
like on it . . . iv googled so many times and can't really find a simular truck to
compare . . . i just wished they would humm like boggers do
Champ74
