more lift ?
purple 'hoe
Green Bay, Wisconsin
If you can find where to add blocks up front, I'll send you $5 dollars for finding it.
However, no lift block of any sort should ever be used on a front axle. Ever. Totally unsafe and would qualify as ghetto fab/hackjob
Here's the bottom line. If you want to clear (and handle) 38's or 39's, you WILL need a Solid Front Axle. Also, I really don't think it will hold together with 38's or 39's with the factory IFS.
No offense man, but you're not ready to tackle a Solid Axle Conversion. If you're dead set on it, start researching. Keep reading into it. I've been reading and planning now for the last 2 years. I still don't really know when mine will ever get done. It's a lot more than cutting some old parts out and bolting on some new parts.
preshus
preshus
washington,IN
dude no offense taken you ain gonna offend me . . . and your totally right
i dnt have the place or the tools to do that . . . i just figured since i
dnt have no front drive shaft for my 4x4 it shouldn't really hurt with
the ifs i got . . . i mean i really dnt ever get off road less its to hunt or
fish every once in a while but even then i still dnt have 4x4 . . . but i
plan on getting an extra set of rims so if i do get these bigger tires
you know when i wanna go play in the mud once i get my drive shaft and
hope to god the guy before me put the same gears up front as the back
i can just throw the smaller tires on to go get muddy lol even tho
my road tires are most likely gonna be boggers lol messed up huh . . .
and i do not understand this block issue you guys are giving me lol
my bronco had a 3 inch block on the front and the back of the frame
and then we fabricated new shock mounts to set them down lower for a
little more lift . . . the blocks were between the frame and body like any
block would be right . . . idk its no big deal if i can't clear em i won't get
em no big deal but i know they should clear fine
purple 'hoe
If I was you, I'd talk to the former owner of it and see what all has been done to it. He's a member on here and GMFullsize.
You have a 6inch suspension and a 2inch body lift right now correct? Which you could run about a 37 inch tall tire. You could take out the 2inch body lift for a 3inch and MAYBE tuck 38's with some trimming if needed.
But remember, IFS+38's is not what I'd be running if it was me. 37's if it's built correct. 38's are pushing it.
If it was me dude, I'd keep it how it is now. Maybe add some 37's on it. It's a clean looking truck as it sits man
992door
Greenville, NC
I don't think it has the same gears front and rear
Yes it has a 6" and 2" BL
the big blue bus
richmond, va
why go bigger though? it looks big enough and the 4wd doesnt even work so kinda pointless. bigger trucks can gett annoying are are pretty usless. mines only got 5 inches on 35s and its a pain when i have to load my latters on the roof. i wouldnt want it any higher. but if your going for looks the i guees the 3inch bl and crank if ya want to fit the 40s and ride like a tank lol
purple 'hoe
This. One reason I'm looking to buy something as a daily driver. It's not practical to do anything with. Other than wheeling or showing off to other people.
Get your front diff regearded. Get a front driveshaft and have fun with it man. It sits up pretty high as is.
preshus
preshus
washington,IN
lol
---------- Post added at 09:43 AM ---------- Previous post was at 09:39 AM ----------
ya i thought the body lift was a block i guess i missunderstood becouse when i put
the blocks on the bronco i thought you just called it a body lift but i found out its
completly illegal for block to be in the front . . . but im really mad to find out that
it might not be geared same as the back . . . i was just looking for a easy fix for
40 inch tires but its no big deal like yall said 37's do look good on it and i know
those will fit no prob . . . lol i don't gotta put nothing on top my rig tho so that dnt
hurt nothing if it goes higher . . . i look more into it bout 38's and see how much
trimming i gota do
the big blue bus
richmond, va
id do that... maybe have to trim bumper corners and hit fender edge in.
side note.. any pics on how he did the lights in diesel bumper? im about to put mine back in and need to figure a better mounting way
preshus
preshus
washington,IN
actually i just picked my truck up so il get piks of it tomorrow sometime
i need to figure out how to wire them up the wireings tied in to so much
crap i dnt know what is what . . . i would figure he woulda spliced into the
head light switch becouse i dnt see no other switch to turn them on
---------- Post added at 07:51 PM ---------- Previous post was at 07:47 PM ----------
hey man i appriciate your input on everything i don't want you thinking
im ignoreing you or anything its just i don't ever really seeing my self
getting the front drive shaft for it so bigger tires should't do any harm
but i just got another set back on the tires any way but i might have
another job comen to me so idk yet . . . i just know in my perspective
or my thought that if you have all that lift on a truck it would only look
right with bigger tires . . . i can't stand 35's really on anything iv just
always ben used to 40's and 38's on all my rides
_Dylan_
STAY FROSTY
You could put a bigger body lift on it.
You can also jack up the truck and check gear ratios by spinning the driveshaft and tires.
ANHannie
