My From Start to Finish 6.0L Build
RAMurphy
RAMurphy
Bob
S. Maryland
TBSS installed and torqued down. What a PITA to get the back three driver side bolts installed and torqued down. I'm taking a little break before I continue all the connections. I'm getting old.....
I've been doing some compression calculations on my own and other research, and I agree with your thoughts/suggestions. Thank you.
I'm sure they're what you're using, but there are some good compression calculators online. I found a really thorough one when I was doing mine. It factored in everything pertinent. You need to know the actual chamber volume of your heads as they vary from the advertised specs, even from the factory.
I just finished up conversations with an engine builder I have utilized in the past and with Tech Support from Texas Speed. Both have stated that the engine I want to build utilizing the rotating assembly I purchased (with flathead pistons) utilizing either the 862 or 243 heads should not be a problem (using premium fuel). As I stated in an earlier thread - I already burn Premium. Texas Speed recommends the 243 heads because they breath better at higher RPMs but said 862 should not be a problem. My engine builder also stated yes 243 heads breath better but since I'm looking at lower RPMs that should not be a problem. Even Roger from Vinci Hi-Performance, who I received my upgraded camshaft from, had no issue with my build. Not sure why BBP has such a concern. The type of heads I end up using is not critical at this point - I may even use after market heads (highly unlikely (cost) but possible). Both conversations included their computation of CR and were similar to what I computed. Texas Speed recommended and computed compression ratio based on the standard head gasket thickness of .051". @iamdub - based on the rotating assembly I ordered there should not be pistons out of the hole. More research to follow.
I'd decide the heads that best compliment the chosen cam. You won't lose any low-end with the 243s so why risk choking (however minimal) at the top end? There's a reason GM switched to them as the standard on the GenIV 5.3. Have you considered pricing out having the 862s CNC'ed? Maybe with larger intake valves (like 2.00" or 2.02") ?
What's the rotating assembly you ordered?
RAMurphy
RAMurphy
Bob
S. Maryland
Thank you for all the input. I'm pretty much leaning towards the 243 heads. After a lot of research and talking to several companies, I'm purchasing a fully balanced rotating assembly from Texas Speed. It will be standard crankshaft, rods, bearings and upgraded piston rings and flat head pistons. Should receive the assembly mid-December. Still researching and quite frankly determining the type/size of the head gasket.
RAMurphy
RAMurphy
Bob
S. Maryland
Completed the TBSS install. Not quite as simple as the multiple youtube posts out there but not that difficult. After install, I needed to reroute some wires and get creative on how I mounted some of the cable brackets on top of the TBSS manifold. I also needed to fix a minor fuel leak but she started right up. Idle was off for about 30-90 seconds but the computer corrected that issue. Disappointed that I was not able to use the Vortec cover, but I haven't given up on that just yet. I can be pretty creative. I still need to record some data for BBP to get the final tune but she runs great. My initial opinion is that I feel that I don't need to step on it as much to get the same result - but when I do really step on it "WOW". Definitely worth the upgrade.
RAMurphy
RAMurphy
Bob
S. Maryland
In the process of putting this project back to together I managed to do something to the the serpentine belt tensioner. not sure how, but is is was squawking a bit. I just ordered an ac delco replacement.
Completed the TBSS install. Not quite as simple as the multiple you tube posts out there but not that difficult. After install, I needed to reroute some wires and get creative on how I mounted some of the cable brackets on top of the TBSS manifold. I also needed to fix a minor fuel leak but she started right up. Idle was off for about 30-90 seconds but the computer corrected that issue. Disappointed that I was not able to use the Vortec cover, but I haven't given up on that just yet. I can be pretty creative. I still need to record some data for BBP to get the final tune but she runs great. My initial opinion is that I feel that I don't need to step on it as much to get the same result - but when I do really step on it "WOW". Definitely worth the upgrade.
Nice work, looks clean.
RAMurphy
RAMurphy
Bob
S. Maryland
Thanks @Rocket Man , really debated on whether I was going to do this now or when I installed the 6.0L. I'm glad I did it now, pretty impressed with the change. A shout out to you for your help - I learned a lot with those connections.
Thank you for all the input. I'm pretty much leaning towards the 243 heads. After a lot of research and talking to several companies, I purchasing a fully balance rotating assembly from Texas Speed. It will be standard crankshaft, rods, bearings and upgraded piston rings and flat head pistons. Should receive the assemble mid December. Still researching and quite frankly determining the type/size of the head gasket.
If the rotating assembly is all stock specs, then the pistons should be out of the hole a few thou, like .004" - .008" at TDC. This always varies between builds (even from the factory) and even seems to always vary between cylinders. Typically, the corner cylinders (numbers 1, 2, 7 and 8) will be more out of the hole than the center ones (numbers 3, 4, 5 and 6). Always measure your assembled one. You'll need a head gasket at least about .037" more than the highest piston, just to give you rough figures.
ford_siesta
