My hefty lighting investment - worth it - Alpharex and Diode Dynamics
intheburbs
SE MI
Did a bunch of research on headlight and foglight options, and settled on the "buy once, cry once" philosophy. I cried. A lot. o_O
Settled on the Alpharex NOVA series LED projector headlights. Click here
And went with the Diode Dynamics SS3 Max LED fog lights. Click here
I wanted quality lights, good cutoffs (too many people driving poor quality stuff and blinding people), and a ton of light. Yes, I just spent $1600 on lighting.
Install went easy (besides the usual GM asshattery of having to rip apart the entire front end) - headlights were plug and play, but they did take a little finagling to get tight gaps with the fenders. The foglights came with all the necessary adapters to make them plug and play as well, and you simply re-use the 6 button clips holding on the OEM fog housings.
One final mod will be adding the 6-light module, so the fogs stay on when the brights are activated.
First impressions....
Headlight cutoff is super-sharp. A buddy riding with me joked that I can use the cutoffs as an aiming reticle if I ever add James Bond-style machine guns up front. A little more narrow of a throw than I'd like. But super-smooth light distribution with zero hot or cold spots. I give them a 9/10, only because I'd like them a little wider of a beam.
Foglights are stupid-bright with a ridiculously-wide throw. You can't overstate how much they light up the periphery. This is great for me because we live in an area heavy with deer. I joke with a buddy that I'm going to start stenciling his Tundra because he's struck 14 deer. Just a ton of light, all where it needs to go. Now, my only complaint is the the foglights are manual - I have to turn them on every time I get in. The 6-hi mod will help somewhat. On a scale of 1-10, I give them a 15. Seriously.
On with some pics....
Before pic:
During pic:
After pic:
Headlight cutoff
Closer
Fog cutoff
Closer
Headlights only (notice reflective barrier)
Fogs only
Headlights and fogs
Lows and Highs, no fogs
Geotrash
Dave
Richmond, VA
Before pic:
During pic:
After pic:
Headlight cutoff
Closer
Fog cutoff
Closer
Fogs only
Headlights and fogs
As I scrolled through your pictures I kept expecting the barrier to burst into flames. They look great!
adventurenali92
Big Bear Lake, ca
So much light output! That’s awesome! I really like those alpahrex headlights. Wish they made those but for my 2006 because they look so sharp! Definitely worth the price tag!
KidWgn
Certified Kid Hauler
St. Louis, MO
Well, you just sold me on the Nova series vs the Luxx series!
Trey Hardy
Eastern North Carolina
Dang man they’re bright! I just replaced my fog lights where a bulb went out but after reading this I’m kinda regretting not spending some more to get the morimoto projector fogs or a set of the diode dynamics fogs like you got.
992dr
Eastern N.C.
That'll definitely get you down the road, that is an extreme amount of output.
Those Diodes WOW, the amount of light they are throwing is impressive. And I like how they mount in the factory location with no mods.
I think I might have to look into them.
intheburbs
intheburbs
SE MI
One last mod - got the Fleece All Lights On module. Fogs stay on with the hi-beams, or if off are turned on with hi-beams...
j91z28d1
looks nice.. I'll have to check this all lights on module. I put diodes in line with my bi-led so they come on in high when the brights are on. but like you said I gotta manually turn the fogs on every time I start the truck. it's only one button but be nice not to have to.
Silentnight008
